A4 Quattro 2.8 Driveshaft
Old Feb 25, 2004 | 11:27 PM
JoRP's Avatar
Default A4 Quattro 2.8 Driveshaft
<FONT face="Arial, Helvetica, sans-serif" color=black size=3>Does anyone have experience with driveshafts or propeller shafts with A4's? I have a 97 that is making a knocking sound. The dealer said it was shot and would cost $1400 to replace. Is this true or can you just replace a CV joint or two? The car has only 115,000 miles. Is it hard to buy 2nd hand driveshafts? Any online suggestions?</FONT></P>
Old Feb 27, 2004 | 04:50 PM
brrman's Avatar
you can replace single CV joints, sure. A bad CV joint will make more of a clicking sound that a knocking sound.
When exactly do you get the knock? all the time? when you turn? hit the brakes?
Old Feb 28, 2004 | 03:56 AM
JoRP's Avatar
I was getting the noise when I was accelerating from 1st through 2nd. For whatever reason I haven't heard it as badfor thelast week. I keep thinking it will just fail though.
Old Feb 29, 2004 | 05:41 AM
g2turbo's Avatar
One way of looking at it:</P>
Better to repair something that has not catastrophically failed then to be stranded with your prop-shaft holding up traffic (after a big truck drives over it). The latter will likely cost MUCH more than getting it fixed now. And if this does happen it'll likely damage more than just the shaft as it lets loose and flops around....</P>
I'd not go to the dealer unless no one else could fix my car. Talk to some independent Audi specialists, and get some quotes from them, including some wrecking yards for a drive shaft (or a good rebuilder).</P>
Best of luck,</P>
Gary</P>
atomm
Feb 15, 2013 12:31 PM
harryb5a4
Feb 1, 2013 04:20 PM
cnterline
Sep 26, 2010 12:01 AM
Rdcarter
Oct 15, 2009 10:38 PM
Splbasshead
May 29, 2009 01:22 AM
