A4 Quattro hesitation with acceleration
Old Apr 8, 2013 | 01:55 PM
stmacdonald99's Avatar
Default A4 Quattro hesitation with acceleration
I have a 2006 A4 Quattro 2.0T and it has a slight hesitation with accelerating from a stop. It is a very quick hesitation but noticeable and irritating. A friend mentioned it may be in the airbox? any suggestions?
Old Apr 22, 2013 | 12:55 PM
CryptoStorm's Avatar
Dirty mass air flow meter or a vacuum leak would easily cause hesitation..
MAF can easily be cleaned.. The easiest way to find a vacuum leak is to start the car and let it idle.. Then spray started fluid on the intake likes that might be leaking.. If the engine idle gets faster: you've found your leak.. The rubber vacuum lines like to crack, and thee are a lot of rubber vac lines on the engine..
grockowitz
Nov 27, 2013 05:04 PM
2000 A6 2.7T Evan
Oct 24, 2013 04:07 PM
BGoux
Oct 4, 2011 09:06 AM
joelsindc
Mar 5, 2008 11:43 PM
SK8R
May 18, 2006 05:45 AM
