a4 recalls for coil/ignition
Old Apr 12, 2004 | 04:48 PM
sdaudi's Avatar
Default a4 recalls for coil/ignition
hi, </P>
anybody have any details on the recall audi/vw did for the coil and ignition problems? how can i find out if a particular A4 is recalled or not.</P>
Old Apr 12, 2004 | 05:28 PM
brrman's Avatar
Call the dealer and have your VIN number handy.
Old Apr 12, 2004 | 08:09 PM
active1331's Avatar
MY firend had that problem with her 2001 A4 and they replaced the coil and now it works great <edited><editID>active1331</editID><editDate>38089.715</editDate></edited>
Old Apr 13, 2004 | 04:51 AM
brrman's Avatar
yeah I think 2001 and 2000 had the coil recall
Old Apr 20, 2004 | 01:50 PM
absltcit33's Avatar
what is it with the ignition that is being recalled? Sometimes I have the problem of turning it on and it won't start, so I have to do it againfor it to work
Old Apr 20, 2004 | 08:42 PM
brrman's Avatar
its the ignition coilpacks that were recalled. If you had a bad one you would know it when your car was running.
You might have a bad temp sensor if your car has trouble starting. Do you have to keep cranking it?
Old Apr 21, 2004 | 12:03 PM
absltcit33's Avatar
no Ill try to turn the engine on, but instead everything else will turn on...radio, A/C, then I i turn back the key and try it again and it the engine will start.</P>
Old Apr 21, 2004 | 06:52 PM
brrman's Avatar
so the car makes no attempt to crank over on the first try??
TheQuattro
Aug 16, 2005 08:06 PM
EngineBuilder
Feb 24, 2004 01:40 PM
AudiTech07
Feb 4, 2004 01:36 PM
marspike
Jan 23, 2004 11:31 AM
a4 qt
Dec 30, 2003 06:54 PM
