A4 to S4
Old Sep 7, 2004 | 06:44 PM
Marcus's Avatar
Default A4 to S4
I've seen the beautiful kit from PES, but has anyone ever added an S4 turbo set-up to an A4?
Old Sep 7, 2004 | 07:03 PM
shon's Avatar
Default RE: A4 to S4
someone over on audizine just did it
they have an extra s4 motor too if your interested... no turbos though
Old Sep 8, 2004 | 09:25 PM
David_K's Avatar
How would you run 2 turbos on that a4. I know split the manifold, but why. you would get so much more power if you just went to a bigger turbo than if you put 2 on there.
Old Sep 8, 2004 | 11:31 PM
shon's Avatar
i was under the impression he wanted to put an s4 motor, not just the turbo setup
Old Sep 8, 2004 | 11:36 PM
p.i.m.p's Avatar
K, since im a newb here, ill ask..........What are all the differences between a4 and s4? Body kit, brakes?, wheels, turbo setup, displacement, gearing???
Old Sep 8, 2004 | 11:41 PM
shon's Avatar
a4 comes w/ a 1.8T
s4 comes w/ a 2.7TT
different front/rear bumpers, bigger wheels...
Old Sep 9, 2004 | 02:12 AM
David_K's Avatar
Better brakes
Better Tranny
Limited slip diffs
Nicer interior (More cushion for the pushin')
More statis
And the list goes on
Old Sep 9, 2004 | 11:32 AM
Marcus's Avatar
A4 - Also 2.8
You want two turbos rather than one large one so that you can cut down on turbo lag and still get high-boost pressures. I would go with a twin turbo set-up because I have a 2.8 and can much more easily adapt the S4s set-up than starting from scratch.
