A4 Speedo Problems , help please
Old Nov 5, 2004 | 01:40 AM
Jestnomen's Avatar
6th Gear
Default RE: A4 Speedo Problems , help please
ORIGINAL: David_K
Thats gonna be a bitch
Nah its actually pretty easy, just take two screws out and the cluster slides out.
Old Nov 5, 2004 | 03:36 AM
99a4audi's Avatar
man goodluck with that project. Thats going to be real expensive it u take it to the dealer, but it might have to come down to it. I was goign to ask if it was under warranty but i dout it. How many miles does it have?
Old Nov 6, 2004 | 01:20 PM
Jonny_doe's Avatar
ok , i've disconnected the dashboard , cleaned connections and replaced ,
jacked the car up and disconnected the connections on the gear box , sprayed them with wd40 and reconnected , went around every wheel and disconnected and cleaned up the speed sensors , and reconnected .. i then drive around the block and every thing was still the same , i.e. no speedo or milage ... So i gave up , packed everything away , washed up and went over to my mates house , which is 1 junction of the motorway away, now when i joined the motorway and got to about 80 mph the speedo jumped back into life , and was fine for the rest of the day , so am now well lost as to what it is ... Any ideas ???
Old Nov 6, 2004 | 03:03 PM
david9999's Avatar
Sounds like a loose ground connection. Anyone have a wiring diagram to wee where they interconnect?
Old Nov 7, 2004 | 11:01 AM
Jonny_doe's Avatar
yes it does sound like a dodgy ground , i went to drive the car again today , and it's not working again
Old Aug 19, 2007 | 11:55 AM
Honda882000's Avatar
I am having the exact same issue. My car is a 98 A4 1.8T and both my speedo and gas gauge are acting up. Problem seems to have started when I went over a tall bump a few weeks back (my car is lowered). Anyone have any luck with this issue?
Old Aug 19, 2007 | 01:00 PM
Jonny_doe's Avatar
No m8 , it just started working , and has been fine for ages now ..
Let me know if you find anything , as i'd love to know after all this time
Old Aug 19, 2007 | 01:08 PM
  #18
discontained's Avatar
probally snag'd a wire .. i would get under and check to see myself i was u.
ORIGINAL: Honda882000
Old Aug 19, 2007 | 04:32 PM
  #19
cmk87's Avatar
SlimChriz you solved the issue for my car thanks
Old Aug 19, 2007 | 09:46 PM
  #20
tdn's Avatar
tdn
My 01.5 did the same thing, but only once on a highway, once I got off, I pulled over and restarted the car.. and it's never happened again. this was about 4-5 days ago.
