A4 starting problem
Old Nov 30, 2007 | 09:08 PM
Bogie's Avatar
Default RE: A4 starting problem
how well did you clean (wire brush) the battery posts AND clamps? If it started bysimply jumping it, it could mean the battery to clamp connection could be loose, or there is a ground short(often in the starter solenoid - it happened on my old VW) causing the battery to drain when you stop the car.After you're 100% sure the battery connections are superclean and there is good contact, then starttrouble shooting foryourground short - start at thestarter solenoid. Good luck, it could take hours to find the short if it is not the starter.
Old Nov 30, 2007 | 09:27 PM
01A4T's Avatar
ORIGINAL: hiwords
actually it does matter on amperage. every battery has an internal resistance that it must overcome in order to power other things. the internal resistance increases and the temperature decrease, thus causing a high internal resistance which results in a lower output power of the battery. i hope you understand wut i said cuz i just learn this in school and i feel very smart being able to spit it back out. if you still don't believe me, go ask any mechanic in a cold climate.
+1. I wonder what kind of cold cranking amps the battery has. You could have just simply bought the wrong battery?
Old Nov 30, 2007 | 09:51 PM
1stgen's Avatar
I didn'tmean that amperage of a battery isn't important. I meant that I have the correct size battery for this application so it doesn't play a role in this problem.
Lourenstien
Oct 30, 2012 07:49 PM
bradwall96
Apr 25, 2011 05:10 PM
PaulA4
Feb 20, 2007 06:55 PM
lhayes
Jun 30, 2006 09:20 AM
PaulA4
Mar 9, 2006 04:30 PM
