ABS+Brake warning went away
Old May 12, 2006 | 11:49 PM
thunderstrike's Avatar
Default ABS+Brake warning went away
Just wanted to let everyone know that I replaced the rear disc brake pads (had 85K on original pads), and it seemed to got rid of the ABS+Brake warnings.
Old May 13, 2006 | 04:53 PM
Jestnomen's Avatar
6th Gear
Default RE: ABS+Brake warning went away
Great news. Let us know if it comes back.
Old May 20, 2006 | 04:12 PM
dankhound's Avatar
Light was probably on due to low fluid level.
Old May 20, 2006 | 11:08 PM
wood_e's Avatar
Good news. When i get my A4 in about a week or so that's the first thing I am going to do to it.
Old May 21, 2006 | 12:09 AM
AteUrV8's Avatar
the ABS and BRAKE light will come on at the same time to let you know your ABS is not functioning properly. did the car accelerate any differently??? its usually just a sensor when these two lights are on at the same time... when u installed your brake pads you probably dusted off the sensor and cleared it up a little bit..
Old May 21, 2006 | 01:18 PM
CRAZYHAWK's Avatar
The brake warning indicator, indicates warn front pads or low brake fluid. The ABS light comes on when there is a problem withe the wheel sensors or ABS module.
Old May 21, 2006 | 02:29 PM
AudiTech04's Avatar
BUT the light that says "BRAKE" will come on when the brake fluid is low
And the brake fluid is usually low because the rear pads are worn, you know cause the brake fluid takes up the space in the brake system
Old May 21, 2006 | 04:00 PM
Galilee's Avatar
I just changed the front pads, and while I was at it, I also grinded the rust off the disks. This meant running the car without the brakes (with ABS sensor) in place. I got all kinds of warnings bleeping and flashing lights. When all was done, i was rid of the orange brake warning, but had the ABS warning light instead.
After braking hard on gravel, activating the ABS, the warning light disappeared.
It seems the ABS and brake warning light will stay on until it's activated, and the system find it in working order.
Just thought I'd let everyone know.
Old May 21, 2006 | 04:04 PM
Beer Mod's Avatar
Sweet
ElDrago
Feb 23, 2012 04:54 PM
rodick
Sep 8, 2008 05:48 PM
manik_ee
Jul 30, 2007 04:46 PM
NuYorka103185
Jan 23, 2007 03:25 PM
