ABS light on
Old Jan 3, 2007 | 11:40 AM
khaoswing's Avatar
Default ABS light on
Once again more electrical problem...(haha) its like as if i'm expecting it...
well the ABS light is staying on permently and also when I release the hand brakes the brake light flashes????
please some word of advice..thanks guys
Old Jan 3, 2007 | 01:10 PM
ddd's Avatar
ddd
Default RE: ABS light on
I have the same problem...... I just got used to living with it for awhile, I think it is one of the wheel speed sensors, probably needs cleaning or replacement.............
Old Jan 3, 2007 | 03:02 PM
tooxtreme8813's Avatar
could be anything from a bad abs unit to a tear or bad ground in a wire
Old Jan 3, 2007 | 11:10 PM
96audia4's Avatar
Have you checked for codes with a VAG?
Old Jan 3, 2007 | 11:13 PM
CRAZYHAWK's Avatar
Old Jan 4, 2007 | 03:12 AM
S_R_N83's Avatar
Your ABS unit needs rebuilt. There are a lot of places that will do it for a couple hundred dollars. A new one from the dealer is ~ 1000 dollars
If you don't mind nothaving ABS, its no big deal.
Old Jan 4, 2007 | 03:50 AM
sean1.8t's Avatar
^^actually it can be an easy fix, just a little soldering of a connection in the controller usually.. if the light comes on and it beeps three times when you turn the key to on before the car's even started, more than likely it's the controller... if you can't connect to it w/ vagcom to check for codes, it's MOST DEFINITELY theABS controller
here is a write-up on how to fix the usual problem with the controller
http://passat-b5.ru/index.php?option...&Itemid=57
Old Jan 4, 2007 | 04:02 AM
SAudi's Avatar
abd wheel speed sensor. i got the same problem it happened to me when a shoit wheel bearing went and somehow took out the sensor. i basically dont have abs to that wheel. im probably gonne replace mine in summer along with the cats.
Old Jan 4, 2007 | 04:12 AM
Trey25's Avatar
Got the same problem but I just ignore it because the brakes work fine. I recently went to a salvage yard and its 150 for a used one. But it comes with the entire ABS (hydraulic side included) which I don't need. I figured I could just replace the controller instead of having it rebuilt or worse going to the stealership. $150 isn't bad huh, what do you guys think?
Old Jan 4, 2007 | 06:58 PM
xAUDIx's Avatar
What about an airbag light? It won go off and it pisses me off. and i dont have a VAG com
