ABS Light
Old Mar 12, 2007 | 11:26 AM
vjmaudi's Avatar
Default ABS Light
Anyone ever have thereABS light come on with the brake light flashing and beeping? Mine has been doing that on and off. I wanted to get a rough idea on what is wrong before I go have the dealer check it out.
Old Mar 12, 2007 | 01:10 PM
akielb's Avatar
Default RE: ABS Light
For future reference always post model info: 2003 1.8t etc.
Flashing is always bad, means that you ABS is not working - I would get it checked out ASAP - might be a bad controler.
Old Mar 12, 2007 | 03:28 PM
Soley4pres's Avatar
Having the same problem.. I had some tips to check out first..vag the car obviously
but could just be low brake fluid..or a faulty speed sensor or a brake light switch
lets hope its not the ABS for both our sakes..big $$ close to $2000 to replace
if you go to the dealer or find anything out post up ..I will do the same
TS
Old Mar 13, 2007 | 04:20 PM
98A4TQ's Avatar
BBA Remanufacturing Inc[/align]BBA specializes in electronic automotive remanufacturing. We provide a quality alternative to expensive new parts. All products are covered by a lifetime warranty. Our eBay store contains a small selection of our inventory. See our website at www.bba-reman.com or call us at (866) 573-2740.
rebuild your abs control module $179.00 and a lifetime warranty
Old Mar 13, 2007 | 04:29 PM
onepoint8tee's Avatar
ABS and BRAKE light at the same time usually means the controller is bad. Try to activate your abs by stomping on the brakes sometime and if they dont activate then its the controller. Scan for codes of course.
Old Mar 13, 2007 | 09:40 PM
BaconBait's Avatar
Bad ABS controller. That BBA site looks pretty good. Most people seem to use www.modulemaster.com $250 and a 5 year warranty
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
