ABS LIGHT A4
ABS light comes on intermittently, fault code 01203 (ABS/Dash pan. ins. electr. consumer No Signal)
I can re-set it but it will come on again with no paticular patten.
Vehicle: Audi A4Q Avant 2.6 1997
Please help
Please help
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Sounds like a problem with the abs module. Disconnect the ABS main power plug and reseat the connector. You may also want to spray it out with some contact cleaner.
Thanks for your prompt reply jestnomen, re-seating and cleaning the main ABS plug
was no good. I am curious why there is such a high number of these ABS failures??
Had a look at other forums and the ABS issue is quite popular. In my case I wounder
if this is all caused by power surches and hence damages the ABS electronics??Not sure
about the next step
about the next step
Hello,
We rebuild the abs module you are having problems with, We have 24 to 48 hour turn around time,we Include a 5 year warranty your cost $249.00
with all updates Included so these failures will not happen again.
Toll Free- 1-800-257-3395 ext 30
Auto & Truck Electronics
www.autoecu.com
www.autoecu.com
mannyg_87
Feb 23, 2015 03:08 PM
crazybk187
Aug 5, 2013 04:29 PM
Pbcrazy
Sep 7, 2012 04:25 PM
