ABS LIGHT A4
Old Feb 21, 2005 | 04:53 AM
haid01's Avatar
Default ABS LIGHT A4
ABS light comes on intermittently, fault code 01203 (ABS/Dash pan. ins. electr. consumer No Signal)
I can re-set it but it will come on again with no paticular patten.
Vehicle: Audi A4Q Avant 2.6 1997
Please help
Old Feb 21, 2005 | 09:47 AM
Jestnomen's Avatar
6th Gear
Default RE: ABS LIGHT A4
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Sounds like a problem with the abs module. Disconnect the ABS main power plug and reseat the connector. You may also want to spray it out with some contact cleaner.
Old Feb 21, 2005 | 06:36 PM
haid01's Avatar
Thanks for your prompt reply jestnomen, re-seating and cleaning the main ABS plug
was no good. I am curious why there is such a high number of these ABS failures??
Had a look at other forums and the ABS issue is quite popular. In my case I wounder
if this is all caused by power surches and hence damages the ABS electronics??Not sure
about the next step
Old Feb 21, 2005 | 09:19 PM
99a4audi's Avatar
check the fluid
Old Feb 21, 2005 | 09:47 PM
haid01's Avatar
Why so, does the brake fluid have anything to do with code 01203?
Old Feb 21, 2005 | 09:49 PM
Jestnomen's Avatar
6th Gear
doubtful....
The ABS module failure is very common. Audi fails to recognize it as a major thing and perform a recall. Too bad, they are expensive.
Old Feb 21, 2005 | 10:57 PM
A4QPR's Avatar
Yep! I have the same problem, a bad ABS Module and you need at list $800 to replace it. Everybody tell me that the brakes will function good but the ABS system not.
Old Feb 22, 2005 | 02:09 AM
Jestnomen's Avatar
6th Gear
cheaper to buy a used one
http://www.car-part.com
Old Mar 3, 2005 | 03:28 PM
Boschabs5.3's Avatar
Hello,
We rebuild the abs module you are having problems with, We have 24 to 48 hour turn around time,we Include a 5 year warranty your cost $249.00
with all updates Included so these failures will not happen again.
Toll Free- 1-800-257-3395 ext 30
Auto & Truck Electronics
www.autoecu.com
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
