ABS light on and Brake light flashes???
Old Sep 16, 2005 | 03:24 AM
wyldstallian's Avatar
Default ABS light on and Brake light flashes???
Anyone had this problem.........ABS light on and brake light flashes. any suggestions???
Old Sep 16, 2005 | 05:20 AM
FezA4's Avatar
Default RE: ABS light on and Brake light flashes???
Take that to the dealer.... theyll know best.....
Old Sep 16, 2005 | 09:22 AM
david9999's Avatar
Have you opened the hood and checked your brake fluid level.
Don't fool around with brake problems. Cars that can't stop have been known to kill people
Old Sep 16, 2005 | 11:48 AM
insuite's Avatar
make sure all the sensors (one at each wheel housing) are firmly seated.
Old Sep 16, 2005 | 11:56 AM
CRAZYHAWK's Avatar
The wheel sensors should be cleaned. That should clear the ABS light. I don't know what is causing the flashing brake light. Read your owner's manual.
Old Sep 16, 2005 | 02:23 PM
acvega's Avatar
Your abs pump is probably dead
Old Sep 16, 2005 | 03:23 PM
luvin_the_rings's Avatar
got the same lights on, they came on right after i was cruising down a hill and the brake pedal started vibrating upon light pressure, then it was silent, "oh ****..." then that dreaded sound, beep, beep, beep
Old Sep 16, 2005 | 03:46 PM
lakeOA4's Avatar
check your brake fluid level.
Old Sep 16, 2005 | 04:59 PM
drkenan's Avatar
Brilliant!!
Old Sep 16, 2005 | 08:47 PM
fluid level is good but i havent cleaned WSS. Dealers cost to much just to plug it into the VAG. Red light is a hydraulic problem.
