ABS Problem
Old Jun 3, 2005 | 01:20 PM
aRIf's Avatar
Default ABS Problem
Hello Everone,
Unfortunately I still have problem with my ABS system. It is still given me pulse on the pedal just before full stop. I am not sure that problem is related with one of my ABS sensor or ABS module. I like to unplug abs sensor cable one by one and try to understand and find out which sensor is bad.
My question is, if I only unplug front sensors, can I drive the car like normal? I know that ABS system will not work on front breaks and it will work like a regular break system. I might get a ABS check light on. Can I clear it, if I unplugged the battery?
I need some advise about it.
Thanks.
Old Jun 3, 2005 | 03:46 PM
BFlan2001's Avatar
Default RE: ABS Problem
you can drive it with your sensors unplugged. i drove with a bad sensor for over a month and it didn't trip the abs light.
Old Jun 3, 2005 | 04:26 PM
Mr_You's Avatar
Bleed the brakes?
Old Jun 4, 2005 | 12:19 AM
Shaunp05's Avatar
Well you can drive with out your speed sensor
you wont have abs just power brakes
on all the wheels, cant split the abs to front or rear
you have to check your sensors and Tone ring
another thing to look out is the gap between the tone ring and sensors...
there should be the same
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
