ABS Pump
Iam looking to replace the ABS pump unit myself on my 2000 A4. Does anybody have any experience with this ? My Chilton maual says leave it to the dealer, since it is easy to get air in the lines.The installation looks simple and I am guessingif you fill the new pump with fluid before connecting the lines and do a good brake line flush you should be good without any air in the lines.
Any information here would be much appreciated
Thanks in advance!!!
Brandon
San Diego [8D]
Brandon
San Diego [8D]
Remove the wheel liner and washer tank, pull the lines, unbolt the pump, and replace. Pretty straight forward really, just bleed the system thoroughly afterwards. Get a bentley manual also.
jsethwerner225
Nov 14, 2014 01:55 PM
james0013
Jul 1, 2009 08:23 AM
