ABS Pump
Old Apr 13, 2007 | 06:03 PM
b_gilhooly's Avatar
Default ABS Pump
Iam looking to replace the ABS pump unit myself on my 2000 A4. Does anybody have any experience with this ? My Chilton maual says leave it to the dealer, since it is easy to get air in the lines.The installation looks simple and I am guessingif you fill the new pump with fluid before connecting the lines and do a good brake line flush you should be good without any air in the lines.
Any information here would be much appreciated
Thanks in advance!!!
Brandon
San Diego [8D]
Old Apr 13, 2007 | 11:04 PM
Trey25's Avatar
Default RE: ABS Pump
Remove the wheel liner and washer tank, pull the lines, unbolt the pump, and replace. Pretty straight forward really, just bleed the system thoroughly afterwards. Get a bentley manual also.
Old Apr 14, 2007 | 01:50 AM
Vaudi's Avatar
sure you dont need the abs control module?
jsethwerner225
Nov 14, 2014 01:55 PM
MetalMan
Jul 19, 2012 09:15 PM
Sardor
Sep 7, 2010 06:02 PM
Deanne
Feb 6, 2008 05:45 AM
