ABS Pump Renewel
Old May 19, 2007 | 06:04 AM
Diamond's Avatar
Default ABS Pump Renewel
hi Does Anyone Know Any Tutorials On How To Do The Abs Pump i have a new Unit To Fit Is It Easy How Do You Bleed The Brakes Etc
Old May 19, 2007 | 10:15 PM
Trey25's Avatar
Default RE: ABS Pump Renewel
This is for the B5, I'm guessing the same principle applies if you have a B6 or B7. Just follow the first few steps, once you have the washer reservoir out the way the pump is held down by only a few bolts. Remove the lines on top and you're good to go Pump removal Pump removal. Bleeding instructions Here, just scroll down to the end.
jsethwerner225
Nov 14, 2014 01:55 PM
MetalMan
Jul 19, 2012 09:15 PM
Sardor
Sep 7, 2010 06:02 PM
Deanne
Feb 6, 2008 05:45 AM
