Adding 2nd Rear Fog
I know some of you don't like the idea of adding a second rear fog to your cars but I am sick of getting calls from tailgating buddies saying one of my taillights are out. I tried to just put a bulb in there but there is a plastic piece over this. Is it as easy as simply cutting that piece out and sticking a bulb in?
yep there is power to it, u just need to cut the plastic to fit the bulb, it will look nice, exept now ur buddies are going to think that ur on ur brakes all the time, at least thats what i get...
Yes there is power there. All you have to do is drill out the hole in the back of the housing, put a bulb in the socket, and put it back together, and you're good to go. Did it a month or so ago, and zero problems.
Well yeah, that would do it. But there are times when they're justifiable. I do run my front fogs a lot of the time for the added visibility, but I leave the rear fogs off unless the conditions really warrant using them. And when they are justified, I figured I'd just rather have two instead of getting pulled over again for a supposed blown taillight bulb.
