aftermarket stereo wiring harness.
I tried the search and found a few wiring harness' but all of the ones I found were either for the bose or incompatible with a 2001 A4. So does anyone know what wiring harness I need to install an aftermarket radio in my 2001 A4? I would like to finally install my avn6610, but I would prefer not to cut up the factory wiring harness.
Thanks
James
Thanks
James
RE: aftermarket stereo wiring harness.
there are 2 ways to get it done 1 get a metra 70-1787 and the bose adapter (not sure what model # it is) and wire it up if you done get the bose/syphony adapter your rear speakers will not work since they are amped but the draw back to this method is that the rear speaker will not be as loud as the fronts but you can use the fader on the deck to balance it out. opition #2 this is the better and cheaper way to done it but it does that a little more work get to the rear speakers like you where going to replace (great time to replace rear speakers if not done yet) and run speaker wires from the green (+) green and black (-) and the purple (+) purple and black (-) from the deck to the rear speakers it is a pretty easy run if you have an idea on how to take your car apart. by doing this it does a couple of different things for you 1 the front and rear will play equally and you will not have to diconnect the bose/syphony adapter ever time you pulg your vag it. if you need the rear speaker adapters to replace the rear speakers let me know by pming me i have them that where used for about 5 mins since i figured out that i didn't need them since my polk momo's fit just fine.
I have a wiring harness from ebay.... but it only connets to three of the blocks from the orignal audi a4 wiring harness... theres still one block that can't connect to any where.... anyone have any clue what to do? I have a 98 audi a4 and mine isn't the bose system... its the concert one...
but my car didnt come witha cd changer.... and they were all plugged in to the back of my cassete radio player...
should i just leave the one that doesnt go into any of the harnesses unplugged?
you get the harness if you got the changer or not it was so when the car was bought new and wanted to pay for the factory cd changer all the techs had to do was mount the cd changer and plug it in
lucky123
04-04-2023 09:55 AM
Nevalite
02-19-2019 02:52 PM
Office04
03-02-2006 09:56 PM
