Ahh! Help! My new Audi starting smoking and lost power!
Old Oct 3, 2007 | 10:24 PM
n3cr0's Avatar
Default Ahh! Help! My new Audi starting smoking and lost power!
Hey Guys,
Being new the forums, its a bummer my first post is about a car problem,butI'm asking for your help. I just got a great deal on a 2001 2.8L A4. However, I had to drive it back home 1600 milesbackto Colorado from New York. Before I left I checked the oil and all fluid levels to ensure everything was where it needed to be, which it was. The car was driving great and I continued to monitor all gauges and fluids during the trip and everything seemed fine. However, after 1500 miles into the trip (basically straight driving) as I was coming in for another gas stop the car seemed to have a significant loss in power and a general feeling of sluggishness (I did not notice while on highway because I was just cruising without using much gas). I thought, gee this cant be good. So i popped the hood and noticed a *small* amount of smoke coming from the engine which lasted for a couple min, and I could also feel a very considerable amount of heat in general coming from the engine. (I had no warnings on the dash of the car) I thought, damn better check the coolant. I did, and found it to be boiling in its resorvoir. So I let the car sit for awhile to cool down, began driving it again and the problem persisted. I finished the drive home and just got back to post to the forums. What could be the problem? What should I do? I'm a bit of a n00b and your advice is greatly appreciated. Thanks a lot everyone.
Oh, and I did do a carfax on the vehicle and there have been no previous problems.
-Alex
Old Oct 3, 2007 | 10:25 PM
n3cr0's Avatar
Default RE: Ahh! Help! My new Audi starting smoking and lost power!
there is 79,000 miles on the car.
Old Oct 3, 2007 | 10:32 PM
auditech79's Avatar
The smoke could either be oil leaking from the cam seals onto the exhaust (most likely) and the overheating concern is probably your thermostat.
Its recommended to do the T belt, thermostat, water pump ect right at 80k so you are right there.
Get that done and have someone check for oil leaks.
Old Oct 3, 2007 | 10:36 PM
n3cr0's Avatar
but none of those things could explain the loss of power? the car feels very sluggish now, much worse than before. I believe there could be an oil leak becuase I did have to add 2 quarts of oil when i got the car, but the oil only seemed to be a fraction lower at the end of the trip...
Old Oct 3, 2007 | 10:39 PM
auditech79's Avatar
Have a diagnostic run while you're getting the timing belt done, our cars will throw a fault code for just about anything.
Old Oct 5, 2007 | 12:42 AM
n3cr0's Avatar
bump. i just realized that i drove from 100ft to 9600 ft and that the change in elevation probably caused about a 50(?)hp drop which is probably a major contributor to all this mess.
Old Oct 5, 2007 | 03:03 AM
Leifer's Avatar
Listen to auditech, he's half-man half-German engineered vehicle, so he'd be able to tell you anything that's wrong. And I do mean *anything*. You don't even have to finish your sentence and he'd give you a statistical analysis of what's wrong.
Old Oct 5, 2007 | 03:33 AM
ocadam's Avatar
How much smoke i know my MAF sensor smokes when i have been driving the car hard. I dont know why been meaning to make a post on it maybe your MAF sensor broke... But IDK just guessing listen to the tech before me tho.
Old Mar 16, 2014 | 11:06 PM
hayyank's Avatar
I have the same issue, did you find the solution?
belikeme
May 16, 2017 12:57 PM
bobby26241
Jun 25, 2012 05:55 PM
Prince Imy
B7 Models
May 15, 2012 09:00 PM
lilmissab
Aug 11, 2008 05:29 PM
forcefedaudi
May 12, 2006 06:31 PM
