aiming non HID headlights
Old Nov 6, 2006 | 12:30 PM
drroy's Avatar
Default aiming non HID headlights
My headlights are aimed to low and the dealer wont adjust them. I have a 2006 A4 quatro. Hoe can I adjust them?
Old Nov 6, 2006 | 02:20 PM
evoic's Avatar
Default RE: aiming non HID headlights
There are 3 bolts that hold the headlight assembly in.
Loosen the 2 that you can easily access from the top.
Once they're loose, adjust to a proper position, hold in place and then tighten the screw back down.
All set.
Old Nov 6, 2006 | 02:26 PM
socaljoe's Avatar
SoCal Crew Member
You don't have to loosen the headlight adjust the aim. If you look at your headlight, on the top, you'll see a small round white plastic. That is just a cover, remove that and you'll see an allen bolt, you adjust the aim with that. Panda had to show me where that bugger was
Old Nov 6, 2006 | 02:45 PM
evoic's Avatar
Even Better ! !
Thanks for that info, Joe. [sm=icon_cheers.gif]
Old Nov 7, 2006 | 09:55 PM
drroy's Avatar
Thanks for the help, I'm on my way out to the garage.
SVT21
May 19, 2008 07:00 PM
Baseballpler
Feb 29, 2008 12:55 PM
akielb
Apr 25, 2007 04:06 PM
OOOO
Jul 3, 2005 04:14 PM
jlaudio184
Apr 27, 2005 11:36 AM
