Aiming Xenons
Old Dec 23, 2007 | 09:52 AM
cantdrive55's Avatar
Default Aiming Xenons
So I replaced my original xenon bulbs yesterday but now they aren't aimed correctly. Currently they direct 90% of the light only about 1ft away from the front bumper! So I tried playing with the adjustment screws but that doesn't seem to do a thing. When going from one extreme of the screw to the other it only raises the light about 6 inches when I'm 15ft from a wall.
I looked at a how to and it told me to go through Vag-Com but when I go to module 55 for Xenon -> 07 for recode and enter in a different number then click "do it" it doesn't change the coding. I see the vagcom screen goes and gives me these two messages, "leu cht wei ter" along the top left and "egler d004" on the right.
I spent almost an hour playing with both vagcom and the manual screws and I still can't seem to get the light brought up. What am I doing wrong??
Old Dec 23, 2007 | 10:03 AM
CRAZYHAWK's Avatar
Default RE: Aiming Xenons
Did you replace all four T-30 screws?
Align the high beams.Make sure the metal
conductor is at 6 o'clock when installing
the HID bulbs.
Old Dec 23, 2007 | 12:20 PM
I didn't take the housings out, I just did it all from the back of the headlights. I can't see back inside the headlight assembly so I'm not sure if the "metal conductor" is at 6 but I put the bulbs back in so that the actual socket is in the same position as they came out.
SVT21
May 19, 2008 07:00 PM
Baseballpler
Feb 29, 2008 12:55 PM
ENDEE666
May 2, 2007 01:18 PM
fusnowtiger
Jan 7, 2007 04:05 PM
Apes
Sep 2, 2006 02:26 AM
