Air Bag Code.
Old Aug 20, 2007 | 11:30 PM
Avant1.8t's Avatar
Default Air Bag Code.
Had my car vag'd. i forget the code but my airbag light was on and it was something like....drivers side air bag ignitor..something along those lines. happened to anyone eles? where should i start?
Thanks.
Old Aug 20, 2007 | 11:33 PM
auditech79's Avatar
Default RE: Air Bag Code.
You gotta post the exact code, it could be the airbad in the driver's seat, the steering wheel, the a pillar, most likely you have a bad air bag. Un-less its in the steering wheel, the spiral clock spring can also cause an air bag light.
Old Aug 21, 2007 | 12:04 AM
Avant1.8t's Avatar
Its the airbag in the steering wheel.
Old Aug 21, 2007 | 01:26 AM
auditech79's Avatar
You probably have a bad driver's airbag, there is a test plan in the VAG COM that you can follow to figure out if its the air bag or the spiral clock spring thats causing the fault code.
Old Aug 21, 2007 | 10:57 AM
Avant1.8t's Avatar
This sucks, airbag's are not cheap at all. will an b5 non sport airbag fit in my non sport steeringwheel?
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
