Air Bag Code.
Had my car vag'd. i forget the code but my airbag light was on and it was something like....drivers side air bag ignitor..something along those lines. happened to anyone eles? where should i start?
Thanks.
Thanks.
You gotta post the exact code, it could be the airbad in the driver's seat, the steering wheel, the a pillar, most likely you have a bad air bag. Un-less its in the steering wheel, the spiral clock spring can also cause an air bag light.
You probably have a bad driver's airbag, there is a test plan in the VAG COM that you can follow to figure out if its the air bag or the spiral clock spring thats causing the fault code.
