air bag light?
I recently replaced my ignition switch. once i got it installed i turned the key to see if it was working properly. The air bag unit was off at this time, so now my airbag light is stuck on, how would i go about getting it off? thanks
If you have a vag-com, I recommend you run the test for all fault codes and then clear them. I had a fault code on my Radio controller that was causing the airbag light to come on. Once I cleared the fault in the Radio controller and then cleared the airbag faults, the light stayed off.
yea i had a problem with my radio code, so the ppl in circut city pulled the radio out for me and i guess you were spossed to take the battery off(my friend told me happend to his jetta too) and they never did so it set my airbag light on, i went to a mechanic got it cleared, it came back in few hours later so i said **** it there are 8 air bags if one dont work another will[sm=devilgrin.gif]
mannyg_87
Feb 23, 2015 03:08 PM
crazybk187
Aug 5, 2013 04:29 PM
Pbcrazy
Sep 7, 2012 04:25 PM
