air bag light?
Old May 20, 2006 | 03:36 PM
GL8386's Avatar
Default air bag light?
I recently replaced my ignition switch. once i got it installed i turned the key to see if it was working properly. The air bag unit was off at this time, so now my airbag light is stuck on, how would i go about getting it off? thanks
Old May 20, 2006 | 10:38 PM
JettaRedII's Avatar
Default RE: air bag light?
If you have a vag-com, I recommend you run the test for all fault codes and then clear them. I had a fault code on my Radio controller that was causing the airbag light to come on. Once I cleared the fault in the Radio controller and then cleared the airbag faults, the light stayed off.
Old May 20, 2006 | 11:13 PM
AteUrV8's Avatar
lol, my air bag light is on also, it goes off after driving for about 5 minutes... its kinda weird, but no biggy
Old May 21, 2006 | 01:44 AM
nmorrow's Avatar
I just got my cluster replaced and the air bag light, abs light, brake light, and the check engine lights are all on.[]
Old Feb 2, 2007 | 01:32 AM
AudiTurbo's Avatar
Well mine all of a sudden has the air bag light coming on, and i dont know what to do?
Old Feb 2, 2007 | 01:45 AM
Sp33d07's Avatar
yea i had a problem with my radio code, so the ppl in circut city pulled the radio out for me and i guess you were spossed to take the battery off(my friend told me happend to his jetta too) and they never did so it set my airbag light on, i went to a mechanic got it cleared, it came back in few hours later so i said **** it there are 8 air bags if one dont work another will[sm=devilgrin.gif]
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
