Air Bag Sign
Old Feb 21, 2007 | 08:34 PM
A4nicator's Avatar
Default RE: Air Bag Sign
By fix the problem, what do you suggest? I disconnected my battery (neg. Terminal) for over 5 minutes and it did not clear. I also checked under the passenger seat to see if there was a loose connection (none that I could find). Now, Im dumbfounded. You said a Vag-com wont fix the issue, so what now? Anything else I can do to avoid the dealership? Im showing a solid light with NO blinking.
ORIGINAL: avant80@2.6
you can read the codes but you cant fix the problem ( srs is a none memory stored system ) so it either works or not and you need to fix the problem or remove the bulb
Old Feb 21, 2007 | 09:14 PM
CRAZYHAWK's Avatar
If you want the airbag to work when crashing, you'll have to fix
the cause of the light.
supercoupe91
Oct 13, 2011 01:06 PM
y^0
Dec 20, 2010 03:19 PM
99turboaudi
May 16, 2009 02:58 AM
Got2Speed
Mar 19, 2008 10:12 PM
