Air filter change
Old Aug 28, 2004 | 02:10 PM
david9999's Avatar
Default Air filter change
How the H does one get the top off the air filter box?
I can with some difficulty access 3 of the clips but there is a 4th clip that is beneath the attached heat shield. The shield is attached by 4 screws, the lower of which are extremely hard to access with a philips screwdriver.
Am I missing some esoteric German engineering reason that a one minute job should take an hour and entail scuffed and burned knuckles?
Old Aug 29, 2004 | 01:08 AM
Doose's Avatar
Default RE: Air filter change
Hey, the good news is it only takes a half an hour the second time. You don't actually have to take the whole top half off to get the filter out. Just pop the top three clips and pry it open enogh to get the filter out. You don't need to remove the heat shield to get the filter out. Now, as for the scuffed knuckles, I still get that after four years!
Old Aug 29, 2004 | 10:57 AM
david9999's Avatar
Thanks for the helpful suggestion. Nothing like brute force to overcome design flaws.
Old Aug 29, 2004 | 03:50 PM
audiboy1618's Avatar
Yeah, back when I changed mine i cut my finger on the air box, yeah, try and explain that. Brute force is all it takes.
Old Aug 29, 2004 | 11:05 PM
CRAZYHAWK's Avatar
The next time I change the air filter, I'm going to tape my right wrist. I also only remove 3 clips.
Old Sep 16, 2005 | 08:00 PM
kextyn's Avatar
Figured I'd revive this OLD thread after I just tried to change my air filter.
I managed to get all 4 clips off, put the new filter in, and barely got 3 clips on and can't get to that last one [:@] I did manage to slice my thumb open on the heat shield though, that was fun [&:]
Daamerikandream1
Oct 7, 2009 09:52 AM
austinpower
Aug 17, 2008 12:05 AM
salaudi
Jun 25, 2008 12:59 AM
Edan
Apr 30, 2005 12:54 AM
david9999
Sep 4, 2004 06:35 AM
