Air Flow Flap
Old Jan 4, 2007 | 11:21 PM
MeadowsMD's Avatar
Default Air Flow Flap
Hey Folks. 1998 A4 2.8L V6 has been running rough off/on for a little while. Codes always came up as "0" (normal funtion). Tonight the car really started running rough. New code popped up "15.7" which according to my chart means "Air Flow Flap, sporadic block".
Anyone know:
1) Where it's located?
2) How hard to change?
3) How much it costs?
Thanks for the help.
Old Jan 4, 2007 | 11:37 PM
onepoint8tee's Avatar
Default RE: Air Flow Flap
"15.7" is not a fault code. Try again!
Old Jan 4, 2007 | 11:45 PM
MeadowsMD's Avatar
It's the code put out on the AC panel. "Code" is a relative term.
Old Jan 4, 2007 | 11:47 PM
oh i c... Sounds like the flap inside the airbox. Take it appart and check it unless someone else has a better idea?
Acutally... Id take it in for an ecu scan. Autozone will do it for free normaly.
Old Jan 5, 2007 | 12:26 AM
MeadowsMD's Avatar
Good to know. Appreciate it.
How long does that scan take?
Old Jan 5, 2007 | 12:29 AM
about 30 seconds. write down the fault code(s) and let us know whats up.
Old Jan 5, 2007 | 06:14 AM
AteUrV8's Avatar
ORIGINAL: onepoint8tee
autozone is amazing... the second i ever get a CEL i take my baby straight to autozone and in 30 seconds i know whats wrong. Get in the zone, AUTOZONE... and check out whats going on
Old Jan 5, 2007 | 06:22 AM
BadLuckAudi's Avatar
or you could get a vag and not have to go to autozone ever again
Old Jan 5, 2007 | 06:56 AM
techbod's Avatar
hmmm so its the blender flap in the aircon your talking about since your quoting A/C codes and your using the A/C to read the codes?? if so you need to use a proper diagnostic tool in the DLC to get engine codes
Pbcrazy
Jan 15, 2013 03:05 PM
Mihkel
Mar 30, 2012 10:02 AM
yellow_submarine
Jun 4, 2011 01:22 PM
audiant
Dec 10, 2006 01:29 AM
