Air flow meter question.
Old Nov 4, 2004 | 02:33 PM
gregp1962's Avatar
Default Air flow meter question.
I keep getting these codes on my 1997 A4 1.8t.
P0118
P0300
P0302
P1559
P0301
P0304
P0303
Someone told me it sounds like it's the air flow meter. Does this sound reasonable to you?
Old Nov 4, 2004 | 03:15 PM
Jestnomen's Avatar
6th Gear
Default RE: Air flow meter question.
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16684,P0300,Random/Multiple Cylinder Misfire Detected
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
Old Nov 4, 2004 | 04:01 PM
gregp1962's Avatar
What do you suppose is causing all these codes? I have a new ignition contorl module and new coolant temp sensor. I have disconnected the battery and let it sit all day disconnected. The light usually comes on as soon as I start it up.
Old Nov 4, 2004 | 04:14 PM
Jestnomen's Avatar
6th Gear
coil packs
Old Nov 4, 2004 | 04:15 PM
PaulA4's Avatar
Sorry to hijack, but how can you tell if the coil packs are playing up on the 1.8t engine?
Old Nov 4, 2004 | 04:22 PM
Jestnomen's Avatar
6th Gear
car shudders, misfires, and a blinking CEL
Old Nov 4, 2004 | 05:42 PM
gregp1962's Avatar
SO far, the answers I've gotten tell me. Air flow meter, camshaft position sensor, coil packs, plugs. It seems unlikely that the coil packs would all go bad at once doesn't it?
BTW, this car is running fine. The CEL is on, but, not blinking.
Old Nov 4, 2004 | 07:15 PM
Jestnomen's Avatar
6th Gear
I'm not sure, cause i have a differnet engine, but I thought it was one unit. And normally when they go, all cylinders misfire.
Old Nov 4, 2004 | 09:42 PM
PaulA4's Avatar
ORIGINAL: Jestnomen
Thanks mate.
Old Nov 5, 2004 | 01:28 AM
SlimChriz's Avatar
Nah there are four coil packs one for each cylinder.
