Almost built!
Old Apr 26, 2006 | 07:01 PM
  #61
TomRitt's Avatar
Default RE: Almost built!
yep aeb def has forged pistons and I'm almost positive the other motors have forged pistons as well (all made by Mahle) but the newer ones only have 19mm wrist pins.
The trouble with the intake is that there is only about 4->5 inches or so b/w the turbo and headlight, I'm going down to the shop to attack again, I'll post pics later tongiht
Old Apr 26, 2006 | 07:07 PM
  #62
BadLuckAudi's Avatar
Sweet cant wait to see the pix, i think if you got the elbow from the 04.5-05 cummins it might work, the bend is really tight
Old Apr 27, 2006 | 05:46 AM
  #63
well were are the pix tom, jeeze lol
Old Apr 27, 2006 | 06:04 AM
  #64
TomRitt's Avatar
Made some more progess...built a flange and finished the downpipe, redid the oil lines, welded the wastegate shut, and cut off the arm, and a couple other things. Looks like i will probably start it tomorrow
Not much room for a filter
Old Apr 27, 2006 | 06:09 AM
  #65
A4 the Quattro's Avatar
dood.. thats going o be one crazy mother ******
Old Apr 27, 2006 | 06:32 AM
  #66
lol yea not much room for anything filterwise, looks like you need some screendoor screen
Old Apr 27, 2006 | 06:34 AM
  #67
and how are you gunna make sure you done blow it with out a good tune to get it to the tuner, lol thats gotta be some mad changes to the fule program to make that big of a turbo set up work.... and whats with that lip thing on the flange is that to direct the flow back instead of going over by the wastegate??
Old Apr 27, 2006 | 06:15 PM
  #68
fenderstrat1184's Avatar
jeeeesus... its times like that that i wonder what youd be doing if you had a b5 s4....
Old Apr 27, 2006 | 06:17 PM
  #69
dan's Avatar
dan
don't think there would be enough room under the hood for 2 of these puppies :P
Old Apr 27, 2006 | 06:21 PM
  #70
badassb5's Avatar
What are you running there for ignition instead of the OE coil packs. I have seen a lot of your engine pics and have just never asked what your runnin.
