Amp hookup
Old Oct 15, 2006 | 02:39 AM
AudiCross's Avatar
Default RE: Amp hookup
Just a crappy old sub. for now... im waiting on getting the molded dash so i can put the deck in. then i will spend my $$ on some real subs. maby some 8" JL W7's. iono. we shall see i guess.
Old Oct 15, 2006 | 02:41 AM
Lazer Viking's Avatar
nice, good luck man
Old Oct 15, 2006 | 06:40 AM
BadLuckAudi's Avatar
75x man is ign on works wonders, so you can run the subs or not makes it nice if you want it to run forever and not drain the batt
ORIGINAL: Lazer Viking
i hooked mine into the fuse for the phone...since i dont have the phone option, it was only hot with the key on so i used it... same concept just different method..what are you going to be running ?
Old Oct 15, 2006 | 06:08 PM
AudiCross's Avatar
Come again? i have no idea what you are trying to say. lol
Old Oct 15, 2006 | 06:10 PM
Johnnyd3689282's Avatar
i actually think the best part is taking our the stock stereo, and trying to put in an indash. Talk about fun, not user freindly, even afyter working in car audio for 3 years, but if you running 12-4 gauge, you should be able to go through a hole around the ecu, but if you running anything bigger than that like 2,1,0, than your going to have to drill a hole in the bottom, and run it under your car, then in and to the trunk. But for you to do it right, without cutting a hole and through the ecu, it should take you about an hour and a half, with hookup.
Old Oct 15, 2006 | 06:46 PM
yea, i had no clue what the hell he was saying either.. i ran 4gauge for mine
Old Oct 15, 2006 | 07:30 PM
yea I ran 4 guage too and no probs but i went a different way not through the Ecu box
ORIGINAL: Johnnyd3689282
Old Oct 15, 2006 | 09:21 PM
  #18
AudiCross's Avatar
Well, since my current sub is only 80 watts (shitty) i ran it to m front passengers seat
and then wired the poiwersupply into the lumbar support. then i spliced into the rear speakers and put that into the higl-level imput on the amp. BAAM! instand sub. if oyu can call an 80w one a sub. but whatever. it works for now.
Old Oct 15, 2006 | 10:18 PM
  #19
lol, im sorry but that sounds like a really ghetto hook up man, lol as long as you dont plan to run it like that forever
Old Oct 15, 2006 | 10:35 PM
  #20
AudiCross's Avatar
Itll run like that. until i get a real sub. but that works fine for now. the current sub is crapy enough that a high level imput from the speakers works just fine. and the wires fro the seat have a 10 amp fuze on em, and the wire that the sub comes with has a 10 amp fuse on it as well, so it works perfectlky.
