Amplifier Recommendations
Old Aug 26, 2004 | 11:58 AM
Andrewuvm's Avatar
Default Amplifier Recommendations
OK-
I've given up on getting my rear speakers to run off of my headunit. Does anyone have any recommendations on a decent 4 channel amp that will run the stock speakers for a little while (without blowing them up) but provide enough power when I eventually get around to replacing the door speakers?
I am going to run all four speakers off of the amp.
Thanks.
Old Aug 26, 2004 | 12:33 PM
hb972.8q's Avatar
Default RE: Amplifier Recommendations
i have an alpine 4 chanel and it unbeliveable. i still have my front stock speakers but have new rear deack speakers. been using this amp and speaker combo for about 1.5 yrs.
Old Aug 26, 2004 | 01:32 PM
Jestnomen's Avatar
6th Gear
you are going to have to replace the back stock speakers to use an aftermarket amp. Bose stuff does not run on a normal 4 ohms, it uses 2 ohms. All of their audio equipment is meant to work with itself and thats it. You might be able to get it to work if you bridge the amp down to 2 ohms though. I've had good luck with alpine amps and U.S. Amps. I used to run a Crossfire amp also, that was pretty good.
Old Aug 26, 2004 | 02:36 PM
Andrewuvm's Avatar
I have a non-bose system.
Old Aug 26, 2004 | 06:41 PM
Jestnomen's Avatar
6th Gear
hmmm....so you are goign to put a bigger amp onto the stock speakers??? That should last a day or two till you blow them.
Filip2
Jun 25, 2013 01:52 PM
AudiPOS2001
Apr 5, 2007 12:00 AM
ToyoBandit
Oct 31, 2006 06:09 PM
plumbous
Jan 11, 2006 02:07 PM
atal420
Feb 18, 2005 02:10 AM
