ANOTHER CEL: P1129 Knowledge Welcome!
Old May 30, 2007 | 07:52 PM
Audi A Fizzle's Avatar
Default ANOTHER CEL: P1129 Knowledge Welcome!
So i thre a brand new check engine code, i used to have all sorts of misfire codes and i had a system too lean code.
I reset those codes after working on a few things and the CEL came back on, only this time its giving me:
P1129 Long Term Fuel Trim mult.,Bank2 System too Rich
My car idles horrible when warming up (guessing something to do with coil packs, or secondary air injection pump)
It also dies in mid-travel every once in a while a few times in a row.
Those are the only symptoms i ahve and i dont think they have anything to do with this new code.
PLEASE HELP!!
Old May 30, 2007 | 08:09 PM
auditech79's Avatar
Default RE: ANOTHER CEL: P1129 Knowledge Welcome!
Could have a bad O2 sensor, and clean your MAF and clear the fault, if it comes back i would bet you have a faulty O2 sensor.
Old May 30, 2007 | 08:16 PM
How many o2 sensors does the car have? And where is the best place to buy a new one?
Old May 30, 2007 | 08:25 PM
auditech79's Avatar
You only have 2 on a 1.8T there is probably only 1 malfunctiong but replacing both would be good preventative maintance. Nothing less than the factory O2 sensors should be used. The price at the dealer is always negotiable remember that when he prices you something bogus.
Old May 30, 2007 | 09:42 PM
Any way ro tell which one is malfunctioning from the code I threw. As much as I would love to replace both I really just can't afford it right now. And I'm sure there has to be an OEM spec o2 sensor made by Bosch or someone that is just as nice as the dealerships. I just hate to give the dealer money for anything.
Old May 30, 2007 | 09:48 PM
auditech79's Avatar
Bosch does make the factory O2 sensors, but i would imagine its your after cat O2 sensor thats malfunctioning thats causing the fuel trim change.
Old May 30, 2007 | 09:50 PM
CRAZYHAWK's Avatar
If you have a 1.8t, you only have bank 1. The code seems bogus.
Old May 31, 2007 | 04:06 AM
david9999's Avatar
There is no 1129 for a 1.8T P1128 however is bank 1, rich.
Old May 31, 2007 | 05:31 AM
techbod's Avatar
P1129 = long term fuel trim, entire speed/load range, bank 2 system too rich,
possible causes are excessive fuel in the oil, fuel pressure, EVAP canister purge valve, injector(s)
Old May 31, 2007 | 08:04 AM
ironman's Avatar
I also pulled the same code, i have the 3.0 one on my after cat O2 sensors, i have 2 i would like to know which one it is, ECS has O2 for 89 plus shipping.
