Another coil pack blown, cylinder numbering?
So much for the newest revision coil pack, I just blew cylinder number 3 before even making it out of the driveway. I'm googling but cant find a diagram for cylinder numbering. Which cyl is which?
Note: Cylinder #1 is closest to the radiator, and cylinder #4 is closest to the firewall. This should make finding cylinder's 2 and 3 self explanatory
Im not sure about the cyl. order on 2.8/3.0, etc. But Im sure its similar with 1 and 4 being the closest to the radiator.
https://www.audiforums.com/m_565488/tm.htm
Thanks, I lucked out and guessed that numbering, and lucked out picking the good coil packs out of the box of bad ones (1 I knew was bad, the other three were 2good 1bad, so the odds weren't horrible).
My next question is, why the hell do these things blow so easily? I started it up and let it idle for 30-45 seconds before the CEL started flashing. I blew two packs right after getting chipped (cyls 1 and 2), and replaced all 4 with the latest revision pack. This one blew in less than a tank of gas on cyl 3. These things should be recalled.
ORIGINAL: chaos92287
probly because you forgot to regap your spark plugs after getting chipped
CaleKessler
Sep 4, 2008 05:06 PM
volari554
Jul 13, 2006 10:57 AM
