any o4 owners have tire pressure monitoring?
Old Dec 26, 2006 | 08:32 PM
ultrasport's Avatar
Default any o4 owners have tire pressure monitoring?
lil stupid question but i just seen a consumer buyers review about 04 a4 and they say that tire pressure monitoring system is standard. I dont think i have this or do i just not know. Anyone with an 04 a4 have this?
Old Dec 26, 2006 | 09:31 PM
tractioncontrol's Avatar
Default RE: any o4 owners have tire pressure monitoring?
tire pressure monitoring systems can monitor pressure 2 different ways, a sensor built into the valve stem (indicated by a metal valve stem), or the pressure can be monitored with the speed sensors. All tire pressure sensors do is monitor variances between the different tires. With speed sensors monitoring them it will notice different wheel speeds and will have an acceptable amount of variance, with pressure sensors the computer will notice too big of differences in the pressures of the different tires. In your owners manual there should be a lists of dummy lights and what each light means, if the book shows a pressure light when you first turn the ignition over look for that light on in the clusterbefore the pre ignition system check is finished.
Old Dec 29, 2006 | 02:07 AM
dankhound's Avatar
The only b series car that has tire pressure monitoring is the rs4.
rreishman
Mar 15, 2008 07:17 PM
lysal
Feb 22, 2008 07:03 PM
helenbol
Nov 4, 2007 07:50 AM
paulsha911
Nov 8, 2006 12:32 PM
toysnob
Aug 25, 2005 11:07 AM
