APR Chip Question (I'm a little dissapointed)
Old May 17, 2005 | 04:16 PM
juju4uofa's Avatar
Default APR Chip Question (I'm a little dissapointed)
I've got a 99' A4 Q 5spd 1.8T. I purchased an APR 93 octane chip but unfortunately I'm not too impressed. I can tell no difference in 1st gear a minimal difference in 2nd and the biggest difference is in 3rd 4th and 5th but still isn't much. My rev limiter jumped to about 7,100 and the turbo got a lot louder but I feel that my added noise to added power ratio is a little off. I'm not bashing the compnay because I believe in their products i'm just trying to figure out what the deal is. The only thing I can figure is since it's non-drive-by-wire the performance gains aren't as impressive. Or maybe I let the numbers go to my head because it doesn't feel like I've added 56 hp and 90 lbs. of torque. Any help will be appreciated.
Old May 17, 2005 | 04:23 PM
acvega's Avatar
Default RE: APR Chip Question (I'm a little dissapointed)
If you haven't replaced you DV, you should. When i got my giac, it alsmost seemed like my boost was messy until i got an aftermarket DV. Stock ones leak under chipped conditions, TT DV are better but not as good as aftermarket.
Old May 17, 2005 | 06:11 PM
flyinb501's Avatar
You should check for leaks and get a boost guage to make sure your boosting proper amount. Give it a few days sometimes it takes the ecu a little while to get used to the chip. Mine def got faster after a few days.
Old May 17, 2005 | 08:14 PM
david9999's Avatar
Agree, replace the diverter valve with a 710N. Unchipped v chipped is night and day.
Old May 18, 2005 | 01:24 PM
juju4uofa's Avatar
I appreciate it guys. I asked APR when I bought the chip if I needed an aftermarket DV and they said no, the one I had was more than sufficient. However they also told me I needed to adjust the height at which my clutch engages by an adjustment on my slave cylinder (I then found out there is no adjustment, the hydraulic clutch is self-adjusting). So I can't help but question the knowledge of at least the guy I was talking to. I consider myself to have good mecahincal knowledge but I've never worked with a turbo. Will i be able to install the DV myself? Thanks again!
Old May 18, 2005 | 01:27 PM
brrman's Avatar
yes the DV is a DIY replacement - a simple replacement by releasing two hose clamps - you might want to have a couple on hand (I think one is the non-reusable kind). 20 mins tops.
Old May 18, 2005 | 01:32 PM
juju4uofa's Avatar
I found a 710N on TTStuff.com for $36.99. They say it's the OEM DV for the new TT. Is this what y'all recommend?
Old May 18, 2005 | 01:38 PM
audihere's Avatar
Banned
get a boost guage to see if ur boosting properly also bc there was a company i went with that ripped me off in sending me fake chips but i threw my reciepts away bc my rents were finding em and they would be pissed if i modded my car..lol
Old May 18, 2005 | 03:55 PM
betz470's Avatar
audihere, lol look at ur car, they didnt know u were modding it?
Old May 18, 2005 | 05:45 PM
flyinb501's Avatar
Yes, thats the most cost effective way to go.
ORIGINAL: juju4uofa
