ASAP HELP with injectors
Old May 29, 2007 | 08:08 PM
2000turbo's Avatar
Member
Default ASAP HELP with injectors
i just put in my new injector seals, and i cat tell if the injectors are in all the way, they seem not to be,
do i need to push them until they go in, or do i just tighten the rail little by little?
and also, when i popped them out i think a bit of dirt went in, how bad is that?
reply ASAP, please
thanks for ur help
Old May 29, 2007 | 08:26 PM
2000turbo's Avatar
Member
Default RE: ASAP HELP with injectors
im kinda sitting here with my car open, so if u guys could help me out that would be great, thanks
Old May 29, 2007 | 08:31 PM
x1rider's Avatar
Make sure you lube the o-rings with a bit of engine oil, they'll go in easier. Here is how I did it: I basically just pushed them in until they stopped sliding and then finished the job by tightening the rail slowly, I doubt you can really push them too far in. I had a bit of dirt fall inside the intake manifold as well when I switched injectors, I don't think it's such a big deal (as long as you didn't get like rocks in there or nothing).
Good luck!
Old May 29, 2007 | 08:44 PM
2000turbo's Avatar
Member
thanks a lot for ur help man
Old May 29, 2007 | 08:46 PM
x1rider's Avatar
No problem, you're welcome.
bkosonen
Apr 15, 2012 12:34 PM
xxipsxx
Dec 11, 2010 03:13 PM
MC Hammered
Feb 4, 2008 12:06 AM
02A418T
Aug 7, 2007 06:23 PM
active1331
Sep 12, 2006 04:46 AM
