audi a4 1.9 tdi starting problems
Old Jun 15, 2007 | 06:54 PM
danny710's Avatar
Default audi a4 1.9 tdi starting problems
I've got a A4 B5 1996 1.9 TDI
The problem is as follows
When I try and start the car from cold it wont start, if I use quick start in the air intake it starts no problem and then will continue to start eventually (about 20 seconds) until I leave it over night again.
I have had all the electrical side checked out at a garage, the glow plugs have been replaced and the relays checked and they are all working fine.
has anybody got any suggestions that I can try before it has to go to a diesel specialist, keeping my fingers crossed it's not the diesel pump as it would probably be as cheap to replace the car.
thanks in advance for any help you can give me.
Old Jun 15, 2007 | 06:56 PM
Audi_Skydiver's Avatar
Default RE: audi a4 1.9 tdi starting problems
Never heard of a TDI A4... Anyways does it have a MAF? Actually nevermind... I have no idea.
Josh
Old Jun 15, 2007 | 07:13 PM
danny710's Avatar
you don't run many turbo diesel cars in america do you
Old Jun 15, 2007 | 07:53 PM
absolute 1.8T's Avatar
I cant walk down the street without seeing a Jeta TDI.... didn't knwo audi had an A4 TDI model... interesting, do they have it in newer years?
Old Jun 16, 2007 | 06:49 AM
danny710's Avatar
Most new audi models are available in Europe as a TDI
Old Jun 16, 2007 | 09:16 AM
techbod's Avatar
Default RE: Audi a4 1.9 tdi starting problems
possible causes are coolant temp sensor/fuel leak and air getting into the system/fuel filter,
a common problem because of its age is the braided pipes that connect to each injector for lubrication the pipes rott and diesel can easily be seen all over them
Old Jun 16, 2007 | 07:01 PM
danny710's Avatar
thanks Dvae, I'll check that out before i send it to the garage, hopefully save me a few quid
Old Dec 15, 2021 | 06:49 AM
jan_s_hanssen's Avatar
maybe you have either a bad battery or fuel filter, fuel pump, high pressure/diesel distributor pump
gordon85
Jul 30, 2014 03:51 PM
Smokin Tubes
Feb 5, 2012 10:11 AM
alexfunari
Jun 20, 2008 08:13 AM
smoovmusicdj
Mar 12, 2008 07:13 PM
hellohellohello
Feb 20, 2007 07:18 PM
