AWE tip chip
Old Jun 9, 2006 | 01:13 PM
dan's Avatar
dan
Default RE: AWE tip chip
AWE is a GIAC dealer
Old Jun 9, 2006 | 02:21 PM
onepoint8tee's Avatar
ORIGINAL: TheJazz7
Oh, and onepoint8...how long has it been since you got your tranny flushed? Or are you on original fluid?
No idea... I dont know if its ever been changed. Im at 75,000 miles, so i should get on it.
Old Jun 9, 2006 | 02:47 PM
TheJazz7's Avatar
ORIGINAL: onepoint8tee
ORIGINAL: TheJazz7
Thanks for clarifying my noobishness Dan
Onepoint8, I could be wrong, but I think the auto tranny fluid is something Audi says "is good for the life of the car" but dilligent owners get changed once or twice regardless. I could be wrong on that, but I'm at work and too busy to search. I think just topping it off with Dexron or Type F fluid is good enough for me (I'm at 43K miles) but I might flush the fluid when I get my timing belt done at 80K or so. If its really dark red or black, change it up. I've heard it costs about $150 and people with higher milage have said it makes for much smoother shifts.
Old Jun 9, 2006 | 03:05 PM
black991.8tq's Avatar
ORIGINAL: TheJazz7
ORIGINAL: TheJazz7
how can u just top it off, since there is no tranny dipstick??? audi auto trans is alot different than a standard auto trans.
Old Jun 9, 2006 | 03:09 PM
techbod's Avatar
because there are 2 plugs on the side of the tranny one to drain and one to fill, the fill pipe was replaced a while back with a plug
Old Jun 9, 2006 | 03:20 PM
techbod's Avatar
just testing some new software for images if its too small just ignore it, I was just trying to post the place where the plugs are
[IMG]local://upfiles/12092/B9C46D2CF1B2403FA1C185364D5F0C9B.jpg[/IMG]
Old Jun 9, 2006 | 03:23 PM
techbod's Avatar
yep crap, too small but ill keep trying and at least it gives you a very rough idea where the are cough
Old Jun 9, 2006 | 04:22 PM
  #18
Jovian's Avatar
Since there is no dipstick you need a vagcom to read the levels properly. And Audi does say the auto tranny fuid never needs replacing which is CRAP. Basically if you notice slips or delays in shifting go to a reputable performance shop and have them do it. Shine Racing Service in Walpole MA is on that will do the tranny fluid.
Old Jun 9, 2006 | 04:26 PM
  #19
techbod's Avatar
you fill til the fluid comes out then put the plug back in that's the way you do it mate
Old Jun 9, 2006 | 05:54 PM
  #20
david9999's Avatar
For the most accurate fill, the fluid temp should be about 49 degrees centigrage. and of course the car has to be perfectly level. A vagcom helps in monitoring the fluid demperature.
