B5 Elim 2871R Logs
Old Mar 14, 2006 | 11:34 PM
aRIf's Avatar
Default B5 Elim 2871R Logs
So Give me some feedback please....
Old Mar 14, 2006 | 11:55 PM
onepoint8tee's Avatar
Default RE: B5 Elim 2871R Logs
Any luck on zine?
Old Mar 14, 2006 | 11:58 PM
aRIf's Avatar
not really, they told me to go to dyno
we also needed to get 031 logs...
Old Mar 15, 2006 | 01:54 AM
trailboss's Avatar
it seems like your pulling timing in the mid rpm range, you have any other loggs. Logg 031 will be helpful. I dont even logg my car much, cause i don't give a sh*t about it anymore, sad...
Old Mar 15, 2006 | 11:30 AM
donsupreme's Avatar
Why don't you care about your car anymore?
ORIGINAL: trailboss
Old Mar 15, 2006 | 12:37 PM
quattrosedan's Avatar
donsuperme, why do you only have 440cc injectors with the 71r kit? Almost everyone that supplies them atleast gives 550cc or 660cc's.
Old Mar 15, 2006 | 12:38 PM
Oh, I did a log last night, trying to figure out what was up with my car...and the mafs was going up to 187g/s at 5k......couldn't get any higher in the rpm range bc of my problem. Why is it diff, as in why does mine suck more air?
Old Mar 15, 2006 | 11:32 PM
trailboss's Avatar
ORIGINAL: quattrosedan
ATPs/ mika software uses larger than 440, he got UNI and they tuned them on 440's at 3 bar.
Clutch is slipping badly, should have been burried a while ago but its still grabbing a little. I have a missfire on cyl 1 at idle when warm i believe its the CP, and im gettin tired of the power, time to go bigger, late summer time something new will be on.
Old Mar 15, 2006 | 11:35 PM
trailboss's Avatar
B/C you still have the stock MAF, well your suppose to with the mika software and it has a smaller i.d. so it is easier to flow more air through. Should be alot higher, up into the 200s, mine was like that but i stopped doing loggs cause my clutch pisses me off, i cant do a run in 3rd without my clutch slippin.
Old Mar 16, 2006 | 02:05 AM
flyinb501's Avatar
Next time log the timing correction factors. I think it is block 20.
