The B5 pod samples have arrived!
Old Apr 25, 2007 | 05:46 AM
MC Hammered's Avatar
Default The B5 pod samples have arrived!
After test fitting only the colour and texture match steps remain!
and if you have a Mk4 Golf/Jetta here is the one for that platform
Old Apr 25, 2007 | 07:09 AM
Belligerenceā„¢'s Avatar
Default RE: The B5 pod samples have arrived!
that looks really nice. do you have a shot of it in-car, to show what part of the cluster it'll block? it looks like it'll only get in the way of the bottom part of the speedo and probably the odometer, is that accurate? I'm really not wanting to block my LCD display, that's my primary concern with a steering column pod.
you're in vancouver I see. what shop do you work out of?
Old Apr 25, 2007 | 07:21 AM
I will have shots of it in car soon when I have the samples installed in various cars for test fitting.
The pod blocks none of the DIS and odometer and almost none of the speedo when we test fit the rapid prototypes in the cars. We were actaully quite surprised at how little information it might block depending on the tilt setting of the steering wheel.
Old Apr 25, 2007 | 08:10 AM
wow I'm surprised you were able to orient the pod in such a way that it doesn't block much of the gauge cluster. what about the volt meter? it's gotta block something... I guess if I had to pick one, the voltage guage is the least important one.
I'm looking forward to seeing these in-car pics.
any idea what pricing will be like on this thing?
Old Apr 25, 2007 | 03:13 PM
less_of_me's Avatar
Sweet! I was dissapointed when I went to the website and saw they didn't have them for the B5. I guess I wouldn't mind if it blocked my LCD screen....as I can only see it clearly 40% of the year....
Old Apr 25, 2007 | 03:20 PM
AML 225's Avatar
ORIGINAL: less_of_me
hahahahhahahahahaha so sad but true.
Old Apr 25, 2007 | 03:36 PM
turbo kraut's Avatar
Tech Guru
i'll do some test fitting for you
Old Apr 25, 2007 | 07:19 PM
LuckyCharmsUXZ's Avatar
ORIGINAL: AML 225
BULLSEYE!
Old Apr 25, 2007 | 07:25 PM
eurokid's Avatar
who makes em? or where do you order em rather?
Old Apr 25, 2007 | 07:44 PM
I make them and you can see the current B6/B7 product at www.podi.ca
The pricing for the B5 pod will be the same as the current B6/B7 product but I will be having presale pricing once I receive my order of gauges for the gauge kits.
The kits will have everything you need to a complete installation.
