B7 Differential and Manual Transmission Fluid
Old Oct 31, 2007 | 09:43 PM
FlyPenFly's Avatar
Default B7 Differential and Manual Transmission Fluid
Dealership says Quattro/Diff fluid and transmission fluid are lifetime but that sounds like crap to me since they consider the Tiptronic fluid lifetime as well when it's rated by ZF for 60k miles.
Has anyone changed their diff or trans fluid yet and what did they use?
Old Oct 31, 2007 | 10:29 PM
hiwords's Avatar
Default RE: B7 Differential and Manual Transmission Fluid
well most of us who have changed out tranny fluids either have b5 or b6. we usually use redline or mobil 75w90 or something similar. as for b7, not 100% it's the same but pretty similar i would think. and change it about evry 55k miles or so to be on the safe side. only problem is u need a vagcom to do it
Old Oct 31, 2007 | 10:51 PM
FlyPenFly's Avatar
Wait, you need Vagcom to change trans and diff fluid?
Old Oct 31, 2007 | 11:34 PM
david9999's Avatar
Vagcom helps. As there is no dipstick, you fill the transmission until it drips out the fill hole. Toget the correct level, the transmission fluid is supposed to be slightly warm (47 degrees C if it remember correctly). That is where the vagcom comes in as you can monitor the temp of the fluid.
In reality, you are probably OK starting with a cold car and driving it around the block once. that should bring you close to the right temperature.The car has to be on Jackstands and be perfectly level.
I use OEM fluid for the tranny and Mobil 1 75/90 for all the differentials.
Old Oct 31, 2007 | 11:46 PM
hiwords's Avatar
well u always wanna make sure u did the job right or let sum1 who knoes how to do it, do it
Old Nov 1, 2007 | 01:19 AM
FlyPenFly's Avatar
I think I'm just gonna bring it La Jolla Autotech when I hit 50k miles.
Old Nov 1, 2007 | 06:41 PM
david9999's Avatar
I think I got off topic. You have a manual transmission. A vagcom is not needed, just drain and fill.
LKaler
Oct 11, 2013 03:30 PM
konabiker47
Jan 20, 2009 09:28 PM
djmika
Jan 1, 2008 07:05 PM
themysteryman83
Oct 14, 2007 06:35 PM
nyaudia498
Mar 3, 2007 01:04 PM
