b7 dv
Old Jun 16, 2005 | 10:58 PM
freshpl's Avatar
Default b7 dv
I understand you can't run a bov on the audi because it runs lean and messes up the cc.
can you run a dv on the b7 audi and still get the swoosh sound you get from a bov and not have issues running lean.
when can you run a bov on the audi?
thank you
Old Jun 16, 2005 | 11:19 PM
freshpl's Avatar
Default RE: b7 dv
what if i chip the b7 would you be able to have a bov then or no?
Old Jun 16, 2005 | 11:21 PM
miked's Avatar
Default RE: b7 dv
stay away from bov period. you would only need to change dv if you chip it, and even then on a b7 i believe it comes with a capable dv (710n as of 2k4 and up right)
EDIT: any b7 tech questions are best answered by jest.
Old Jun 16, 2005 | 11:22 PM
GTMA4's Avatar
Default RE: b7 dv
On the b7 you don't need to get a dv unless you are really pushing a lot of boost. I mean the BOV would be running extremely lean, and you would void your warranty by changing out the DV with a BOV. You should hear the whistling noise when you are accelerating, but you won't hear the big swoosh you want...Although Blitz does make a dual sequential specifically for audis, but your engine is too new at present you wouldn't find an immediate bolt on...but that is just my opinion.
Old Jun 16, 2005 | 11:24 PM
freshpl's Avatar
Default RE: b7 dv
thanks for your opinion guys
Old Jun 16, 2005 | 11:53 PM
cgv988's Avatar
Default RE: b7 dv
correct me if i'm wrong, but i was under the impression that a BOV caused the engine to run too RICH, which would in turn result in a clogged cat, soot deposits in the exhaust, messed up O2 sensr, and bad milage.
Old Jun 17, 2005 | 01:15 PM
Jestnomen's Avatar
6th Gear
Default RE: b7 dv
Correct a BOV causes the engine to run rich. On the B7 the DV is different than on previous A4's. The DV is integrated into the turbo assembly and is controlled electronically. You can't just slap a new one on.
Old Jun 17, 2005 | 04:53 PM
Nasty's Avatar
Default RE: b7 dv
yeah but you've allready got the 710N so you wouldn't really NEED to swap it out inless you were running like infinity pounds of boost.
Old Jun 17, 2005 | 08:25 PM
Jestnomen's Avatar
6th Gear
Default RE: b7 dv
No, the new DV on the B7 is completely different.
