Back seat?
the bottom part of the seat just pulls up.
the backs are pretty easy to remove too......but you need a torx bit. you need to fold both seats down. in between them is where they bolt in. there is a little plastic cover that you need to pop off in order to access the screw that holds a bracket down. once you remove the screw a metal piece holding the pivots for both seats will come off. then all you need to do is lift the seat out of the holder and pull it out from the side if the car.
