Is this bad?
Old Oct 21, 2007 | 11:27 PM
FaenaAzul's Avatar
Default Is this bad?
Hi guys,
CEL came on. Here's the scan:
1 Fault Found:
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 - 92-00 - Unknown Error Elaboration
Readiness: N/A
Any ideas? Should I clear the fault and see if it comes again, or is this something I should be worried about? TIA.
Old Oct 21, 2007 | 11:29 PM
auditech79's Avatar
Default RE: Is this bad?
Given the unkown error code i would try clearing it first to see what it does, if it comes back it looks like you have to replace the passenger's side after cat O2 sensor.
Leifer's Avatar
What's that...
It's a bird, it's a plane
NO, IT'S AUDITECH COMING TO RESCUE YOU
Edit: Damnit you beat me by 30 seconds. I saw you lurking this thread.
Old Oct 21, 2007 | 11:31 PM
FaenaAzul's Avatar
lol @ Leifer.
Thanks auditech!
Old Oct 21, 2007 | 11:34 PM
auditech79's Avatar
ORIGINAL: Leifer
What's that...
Thats what i do, all for free too. [8D]
Old Jan 9, 2008 | 10:37 AM
FaenaAzul's Avatar
OK, I am now having the exact same error. Is there anything else I could do besides changing the front right O2 sensor?
TIA
Old Jan 9, 2008 | 10:45 AM
hiwords's Avatar
it's not the front right. it's the rear right. you could take it out and spray the crap out of it with intake/throttle body cleaner. it might help for a bit but the part is really easy to change. you jsut unscrew it, follow the wire to the top of the engine bay, then unhook the harness and do the opposite for the new one. or a cheaper solution is to get a 4 wire o2 sensor, cut the wires after the harness and splice the new one in.
Old Jan 9, 2008 | 10:51 AM
Papachristou's Avatar
[/quote]
[/quote]
wanna give me some free b6 clutch removal advice for this weekend? ill surely need it and/or a copy of the bentley pages for it...... i have all the DIY from audiforums, AW, audizine and a4mods printed and reviewed them... just got to pick up some triple square sockets for the driveshafts...
Old Dec 23, 2008 | 06:25 PM
FaenaAzul's Avatar
Hi guys, thanks for the previous advice, I changed the O2 sensor and everything went back to normal.
Today I just got a CEL again, I was hoping to hear your thoughts about them:
3 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 92-00 - Unknown Error Elaboration
17658 - Fuel Level too Low
P1250 - 68-00 - Cylinder 1
16688 - Cylinder 4 Misfire Detected
P0304 - 64-00 - Not Currently Testable
The car is driving wonderful as usual. Should I clear the codes and wait?
TIA.
