is it bad that I turned the cam gear the wrong way
Old Aug 2, 2005 | 11:31 PM
turbo's Avatar
Default is it bad that I turned the cam gear the wrong way
is it bad that I turned the cam gear the wrong way.
now when I turn the car over it sounds like the gears are running free and not turning the car over.
Old Aug 2, 2005 | 11:33 PM
goldenchild's Avatar
Default RE: is it bad that I turned the cam gear the wrong way
i wouldnt be tryin to turn ur car over bc i think its going to mess up ur timing. very very bad
Old Aug 2, 2005 | 11:36 PM
turbo's Avatar
To Late. Now how can I fix this and why is it making that sound like the car is not turning over?
Old Aug 2, 2005 | 11:40 PM
put it back to where it lines up. its doin that bc if a car is out of time it wont start and by doin this u can bend some valves and these engines are easy. y were u messing with it anyways? timing belt replacement?
Old Aug 2, 2005 | 11:53 PM
lidonnit's Avatar
Depending on how much you turned it you could be up for a new head replacement, possible engine re-build. If your lucky you can turn it back & see if it will run. What were you trying to do?
Old Aug 3, 2005 | 12:13 AM
Beaner's Avatar
yeah..why where you turning it in the first place?
Old Aug 3, 2005 | 12:23 AM
turbo's Avatar
Yah timing belt.
O CRAP
Old Aug 3, 2005 | 12:25 AM
turbo's Avatar
Well I re set it at top dead center and it is still sounding like the pullies are spinning free.
Old Aug 3, 2005 | 12:53 AM
Beaner's Avatar
oh geez
Old Aug 3, 2005 | 01:51 AM
turbo's Avatar
I am going to do a compresson in the morning do you know what LB it shoul be at each cylinder?
