Bad Missfire Problem - yes I have searched :)
Old Feb 17, 2007 | 04:48 PM
onepoint8tee's Avatar
Default RE: Bad Missfire Problem - yes I have searched :)
ORIGINAL: futebol3
+ 1 on ICM. Sounds like the exact same thing that happend to me and it turned out to be the ICM.
Also, after I got a new ICM my CEL from my 2nd O2 sensor stopped showing up..wierd...
Its not wierd because when you misfire, unburnt fuel/gasses are going into the cat and "shocking" it.
Old Feb 17, 2007 | 04:54 PM
qwho387's Avatar
Thats good to know. I bought the o2 sensor already but im going to let it sit with the receipt in the box till I get this figured out.
Old Feb 17, 2007 | 04:56 PM
ya you most likely wont need it. misfire codes are usually accompanied by 02 sensor codes if the misfire is severe enough.
Old Feb 17, 2007 | 07:33 PM
qwho387's Avatar
Severe indeed. I just tested the ICM with a multimeter and the cycinder 2 pathway is totally closed. That would be it. I was however getting missfires in other cylinders too. Can missfires cascade like that from one cylinder or is it likley that I have a bad coil pack or two as well?
Old Feb 17, 2007 | 07:42 PM
Ya its very possible the ICM could cause random misfires since it controls the firing order,and settle on a #2 misfire when its dead.
Old Feb 24, 2007 | 06:37 AM
qwho387's Avatar
Ok, so I replaced the ICM the other day and got her running again. Was only getting like 15MPG and the O2 sensor code was comming back on. Ok, so I replaced that and I am getting about 24MPG 1/2 city & highway. now im feeling a bit better about selling it but I noted a small missfire when I was driving., No code though...
Old Feb 24, 2007 | 01:46 PM
acetrebo's Avatar
You may want to reset the ecu just to clean up and let the ecu re-adjust, and clear anything hanging around in the ecu.
Just pull the neg. bat cable for a few minutes. make sure you have your radio code.
Gald to hear the ICM and o2 took care of it for ya.
Old Feb 24, 2007 | 10:29 PM
  #18
A4Rollin's Avatar
I used to have a 98' A4 that was chipped and the check engine light would ALWAYS come on. Everytime I went to the audi dealer to see what it was, the computer kept saying missfire in 3 and 4, and failure o2 sensor.It was a pain in my a$$ and never figured it out. Just selt with it for awhile until i totaled it, kinda happy I did cause that car was a lemon. Everything went wrong with that little f***er
markymarc
Apr 20, 2009 01:36 AM
kmill58
Dec 17, 2007 07:06 PM
dj_lex
Nov 6, 2007 05:23 AM
Novablue454
Oct 23, 2005 07:15 AM
