is it bad to switch between chipped and stock while driving?
Old Nov 19, 2006 | 01:50 AM
Boober's Avatar
Default RE: is it bad to switch between chipped and stock while driving?
mpg
Old Nov 19, 2006 | 01:59 AM
SurferForever's Avatar
Does chipping it really use that much more gas?
Old Nov 19, 2006 | 02:39 AM
Boober's Avatar
ORIGINAL: SurferForever
not really...like 3 mpg, i just that it might be a reason for stock
i've had mine on stock for the last week because i bought it with the chip and want to see what it feels like stock compared to chipped
Old Nov 19, 2006 | 06:17 AM
socal_A4's Avatar
No I do it.. No probs at all... All your doing is just telling your ecu to change up the fuel/air ratios.. and allow more boost...or vice versa
Old Nov 19, 2006 | 09:49 AM
david9999's Avatar
Actually, I got improved mileage when I chipped my car. Of course, if I punch it, that is something else.
Old Nov 19, 2006 | 03:59 PM
Boober's Avatar
ORIGINAL: david9999
it's hard to lay off the foot when its chipped too
Old Nov 19, 2006 | 07:58 PM
ultrasport's Avatar
depends if your ecu was soldered or flased. flashed you need to switch with car off, if its soldered you can switch on the fly, but APR rep did tell me its better to switch while stopped, not sure why but it wsa for mechanical reasons not just safety.
Old Nov 20, 2006 | 02:40 AM
  #18
Bondga's Avatar
Noooo... Don't switch the programs while drivin!!!!! High boost to low boost is ok but low boost to high boost will spike the turbo and can cause you to throw a rod. I found this out the hard way here's some pics of what happens
This used to be a Boosted K20
If you want to change it while driving throw the clutch in let it idle then switch the program then go back to driving.
*That 3rd picture- Yes that is a screwdriver holding the engine on the stand. The rod blew off the engine mount when it went.*
Old Nov 28, 2006 | 12:17 AM
  #19
Boober's Avatar
nice pics man, must have been one hell of an experience from inside the car... so driving, putting the clutch in and coasting and then switching the chip, and letting the clutch out is cool?
incrementalg
Jul 2, 2008 08:40 PM
mrvuml
Oct 15, 2007 09:37 PM
.clipse
Jul 27, 2007 12:53 AM
crd945
Jan 2, 2007 06:27 PM
socals4driver
Sep 27, 2006 05:01 AM
