bad throttle body?
Old Sep 12, 2007 | 03:13 PM
SacTown_Vlad's Avatar
Default bad throttle body?
alright another problem in my a4, I’m running 14-15psi and it spikes 16-17 once in a while (diode mode). I was fine for a few weeks, but few days ago I was playing with WRX… i know it was stupid … ok … i was running fine and then I hear this BOOM! it sounded like balloon just popped, I wasnt sure what happened, maybe It wasn’t me, but right after BOOM my rpm dropped and my boost dropped from 14psi to 3or4. So I slowed down a little and tried to accelerate again, and I have no power and my boost goes to 10psi for a second then drops to 4, I pooled over closed my mbc all the way and still boost jumps to 10 for a sec and holds only 5psi… before it was spiking 21-22psi.
1st thought was one of my vacuum tubs popped so I started looking for cracks in a tube, but couldn’t see any, so i connected compressor to one of the tubs and nothing … all lines was fine and hold pressure… then I pooled my dv, it seems it perfectly working condition. last thing I did is cleaned my throttle body and realigned it.
So everything seems ok and I took it for a test drive, i was surprised to see 17 psi again, so I was like aright, everything fine, no worries. but yesterday on the way from work I was little hard on my car again and i lost power again, no BOOM sound this time, it still pools kind of ok till I hit 3.5 RPM, and feels like I have 100 ppl in my trunk on higher rpms.
anyone experienced it before? I would hate to spend $$ on new tb if original can be fixed. I will definitely try to clean contacts on throttle body today.
any other thoughts?
Old Sep 12, 2007 | 03:20 PM
onepoint8tee's Avatar
Default RE: bad throttle body?
Probably not the TB. Get your ecu scanned, your might be overboosting/going into limp mode. If you could be more descriptive about "boom" that would help. Did it come from the rear like an exhaust/backfire boom, or from the engine like severe detonation boom?. Get the ecu scanned.
Old Sep 12, 2007 | 03:27 PM
diode wouldn’t let me go into limp mode, haven’t scan my ecu but my cel is off. it really sounded like balloon pooped, i was driving around 60 so i have no idea were it came from and i had few cars around me, like i said I’m not even sure sound was from my car.
Old Sep 12, 2007 | 03:37 PM
i’ll check my ecu tonight, but I wasn’t thinking about limp mode only because some other code, not over boosting, would at least flashed sel before getting me into limp mode …
Old Sep 12, 2007 | 03:56 PM
ORIGINAL: SacTown_Vlad
i’ll check my ecu tonight, but I wasn’t thinking about limp mode only because some other code, not over boostingwould at least flashed sel before getting me into limp mode …
You dont always get a CEL when in limp mode. I dealt with limp mode issues off and on forovera yearand never had a CEL.
kraylon
Sep 2, 2009 09:32 PM
neomaxddr
Apr 1, 2009 03:15 AM
MilitantGrunt
Aug 13, 2006 09:01 PM
16w/A4
Jul 24, 2006 10:12 AM
