Bailey's Diverter Valve
Old Oct 30, 2006 | 10:07 PM
Boober's Avatar
Default Bailey's Diverter Valve
i'm looking to buy an aftermarket dv, i'm thinking about a bailey's, and i was wondering if anybody knows if they can be opened for cleaning and replceing the spring. i think all aftermarket dv's are serivceable but i just wanted to make sure, and i read that the forge springs will work in the bailey dv's, if so what spring color should be used? i always read different colors and different rates...sometimes i hear that the blue is the strongest and sometimes it the yellow...can somebody tell me what the correct rates are? thanks
Old Oct 30, 2006 | 10:51 PM
Ford2Audi6's Avatar
Default RE: Bailey's Diverter Valve
i actually just bought a forge 007 and i was also wondering what the best spring for the dv would be. sorry to get in on this thread boober but i have the same question hopefully we get an answer.
Old Oct 30, 2006 | 10:55 PM
chuckievi's Avatar
Well the different springs go for different PSI levels. I am using the green spring, and I peak at around 21psi. So really you need to know your psi and then find the corrosponding spring.
as to whether or not forge springs work in a bailey's, no idea
Old Oct 31, 2006 | 12:37 AM
Boober's Avatar
ORIGINAL: Ford2Audi6
no worries man...it's just weird that i've searched on this topic and everybody seems to have something different about which color to use. i 'm running the APR chip and i want to get an aftermarket dv, but it won't do any me good unless i know how to use it, which spring to use.
Old Oct 31, 2006 | 12:41 AM
chaos92287's Avatar
a couple of bailey's dv's are up for sale in the classifieds section right now for 100. they're normally 150. might wana check it out
Old Oct 31, 2006 | 01:44 AM
chuckievi's Avatar
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
thats the color corrospondence according to Forge motorsports. So most people will use green, MAYBE yellow
Old Oct 31, 2006 | 02:23 AM
Ford2Audi6's Avatar
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Thanks man, I will have to put the green one in.
Old Oct 31, 2006 | 11:39 AM
eurokid's Avatar
from what i've read the bailey's dv is pretty reliable and can handle pretty hi boost levels
Old Nov 3, 2006 | 04:05 AM
Boober's Avatar
yeah...i've heard more about the bailey's being really reliable...but as far as aftermarket dv's go...i think they're all probably pretty reliable.
Old Nov 3, 2006 | 04:06 AM
Boober's Avatar
ORIGINAL: chaos92287
thanks man...i'm going to check them out.
does anybody know if the forge springs will work in the bailey's?
